GRIPBLOCK system variable
Grips in blocks
Displays grips on entities inside a block, when a block is selected.
The insertion point of the block is displayed regardless of this setting.
Type: | Boolean |
Saved in: | Registry |
Default value: | Off |
Possible values: |
Off (0): Doesn’t display grips on entities within the block On (1): Display grips on entities within the block |
