HPTRANSPARENCY system variable
Default transparency for new hatches
Specifies the default transparency level for new hatches.
Type: | String |
Saved in: | Drawing |
Default value: |
Possible values: |
.: Use current ByLayer: Apply the layer’s transparency ByBlock: Apply the block’s transparency 0: Apply no transparency (fully opaque) 0-90: Apply transparency percentage from least (1) to most (90) transparent |
