IFCMATCHIMPORTEDPROFILESGEOMETRICALLY system variable
Import: use profiles from databases with corresponding geometry
Compares profiles with the project and central database based on their geometry during IFC import. If it matches, the parameters defined in the project/central database (profile name, size and standard) are used instead of imported parameters.
BricsCAD only
Type: |
Boolean |
Saved in: |
Registry |
Range: |
0 to 1 |
Default value: | 0 |
