LOFTANG1 system variable
Loft angle 1
Sets the angle at the first cross-section, for the LOFT command, modifies the loft shape. Works only if the LOFTNORMALS system variable is set to Surface uses draft angle and magnitude.
Values between 0.0 and 360.0 are accepted.
Type: | Real |
Saved in: | Drawing |
Range: |
0.0 to 360.0 |
Default value: |
90.0 |
