MSOLESCALE system variable
Model space OLE scale
Controls the size of an OLE (Object Linking & Embedding) entity, that contains text, when pasted into model space. Entities already placed in the drawing are not affected.
If set to zero, uses the DIMSCALE system variable.
Type: | Real |
Saved in: | Drawing |
Range: |
0.0 or greater |
Default value: |
1.0 |
