OLEFRAME system variable
OLE frame
Controls the display of a frame around an OLE object, if the FRAME system variable is set to Use individual system variables (3).
Type: |
Short |
Saved in: |
Drawing |
Range: |
0 to 2 |
Default value: |
2 |
Possible values: |
0: No OLE frames 1: Display and plot OLE frames 2: Display but do not plot OLE frames |
