PDFIMPORTJOINLINEANDARCSEGMENTS system variable
Join line and arc segments
Joins continuous segments into a polyline, where possible, during PDF import.
BricsCAD only
Type: |
Boolean |
Saved in: |
Preference |
Range: |
On |
Possible values: |
Off (0): Don’t join the line and arc segments from imported PDF files On (1): Join the line and arc segments from imported PDF files |
