PICKBOX system variable
Pick box
Controls the selection area size around the cursor, in pixels.
Values between 0 and 50 are accepted.
Note: If you select an entity by clicking, the Pick Box must touch or overlap the entity.
Type: | Short |
Saved in: |
Registry |
Range: | 0 to 50 |
Default value: | 4 |
Unit | pixels |
