PROJECTSEARCHPATHS system variable
Project search paths
Stores a list of project names, each with a list of file paths to search.
If external references and images are not found in the saved path, the project search paths are used to find the external references and images.
Separate file paths with semicolons (;).
BricsCAD only
Type:
String
Saved in:
Preference
