PROMPTOPTIONTRANSLATEKEYWORDS system variable
Prompt option translate keywords
Loads translated command option keywords.
If disabled, English keywords are used and global shortcuts can be used without an underscore.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | On |
Possible values: |
Off (0): Don’t load translations of keywords On (1): Load translations of keywords |
