RE_INIT system variable
Reinitialize Aliases (Read Only)
Reinitializes the digitizer, digitizer port and/or reloads PGP file (command aliases).
Type: |
Short |
Saved in: |
Not saved |
Range: |
0 to 21 |
Default value: |
0 |
Possible options: |
1: Digitizer input/output port reinitialization 4: Digitizer reinitialization 16: PGP file reinitialization (reload) |
