REDHILITEPARTIAL_SELECTEDEDGEGLOW_SMOOTHING system variable
Glow smoothing
Displays smooth (anti-aliased) lines for the glow effect on an edge, when selected. See also the REDHILITEPARTIAL_SELECTEDEDGE_SHOWGLOW system variable.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | On |
Possible values: |
Off (0): Smooth glow lines off On (1): Smooth glow lines on |
