REGEXPAND system variable
Registry paths expanding type
Controls the types of paths stored to a registry (absolute or expandable).
Note: A re-start is required.
BricsCAD only
Type: | Boolean |
Saved in: | Registry |
Default value: | On |
Possible values: |
Off (0): Don’t store paths in a portable format using environment variables On (1): Store paths in a portable format using environment variables |
