RUNASLEVEL system variable
Run as license level
Runs the program in a different (lower) level than the licensed level. If the licensed level is lower than RUNASLEVEL, RUNASLEVEL is ignored.
Note: A restart is required.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 5
Default value:
5
Possible values:
0: Lite
1: Pro
2: (Obsolete)
3: BIM
4: Mechanical
5: Ultimate
