SHEETSETAUTOBACKUP system variable
Sheet set automatic backup
Creates a backup file when a Sheet Set file is opened.
The backup files must have the same name as the Sheet Set file but with a 'ds$' extension.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Don’t create backup files
On (1): Create backup files
