SHOWDOCTABS system variable
Tabs visibility
Toggles tabs on/off, in the documents tab.
You can make the drawing area larger by hiding the document tabs from the user interface.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t make tabs visible
On (1): Make tabs visible
