SMASSEMBLYEXPORTSOLIDTYPESINREPORTS system variable
Solid types in reports
Determines which types of solids will be present in command reports. Each solid belongs to one of four types: sheet metal, poor sheet metal, non sheet metal or standard part component solid. Sheet metal and poor sheet metal solids are always present in the reports.
BricsCAD only
Type: |
Short |
Saved in: |
Drawing |
Range: |
0 to 3 |
Default value: |
0 |
Possible values: |
1: Non sheet metal solids 2: Standard part component solids |
