SPAGRIDMODE system variable
Grid mode
Controls how grids are used in the mesh process. This variable is ignored if FACETRES is used.
The grid mode specifies whether a grid is used and whether the points where the grid cuts the edges should be inserted into the edge discretization.
Note: Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 3
Default value:
1
Possible values:
0: Do not subdivide faces with a grid
1: Use a grid but do not add model edge intersection points
2: Allow grid to divide model edges
3: Grid only in one direction, u or v
