SSLOCATE system variable
Sheet Set locate
Opens any associated sheets sets when a drawing is opened.
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t open a drawing's Sheet Set with the drawing
On (1): Open a drawing's Sheet Set with the drawing
