SURFTYPE system variable
Surface-fitting type
Controls the surface-fitting type used with the Desmooth option of the PEDIT command.
Type:
Short
Saved in:
Drawing
Range:
5 to 8
Default value:
6
Possible values:
5: Quadratic B-spline surface
6: Cubic B-spline surface
8: Bezier surface
