TSPACETYPE system variable
Text space type
Controls the type of line spacing used for multiline text.
  • At least: adjusts line spacing based on the tallest character(s) in a line
  • Exactly: uses the specified line spacing, regardless of individual character sizes
Note: The mtexts created with the MLEADER command are also influenced by this system variable's value.
Type:
Short
Saved in:
Registry
Range:
1 to 2
Default value:
1
Possible values:
1: At least
2: Exactly
