VOLUMEPREC system variable
Volume precision
Controls the number of decimal places displayed for volumes, if volume properties are formatted with the PROPUNITS system variable.
If negative, LUPREC (Linear Unit Precision) is used.
BricsCAD only
Type: | Short |
Saved in: | Registry |
Range: |
-1 to 8 |
Default value: |
-1 |
Possible values: |
-1: Use the LUPREC system variable 0 1: 0.0 2: 0.00 3: 0.000 4: 0.0000 5: 0.00000 6: 0.000000 7: 0.0000000 8: 0.00000000 |
