BIM window create
Commands
BIMWINDOWCREATE
About
In BricsCAD®, the Window Creator tool allows you to turn a different set of design ideas into a window. You can use the tool on windows of all shapes and sizes, which enables you to utilize a significant amount of window styles in your BIM project.
Creating a parametric window using boundaries
- Draw a polygon on the face of a solid (wall).
Based on this base profile, the window opening will be created.
- Make sure Boundary Detection (select detected boundaries) is enabled into SELECTIONMODES system variable. Hover over the inside of the polygon and select the Create Window tool from the Quad.
A Choose Window Style dialog box displays:
- Select a window style in the dialog box.
The window is created on the wall with the selected style. The following illustration shows the triple panel left window style which was selected to create the windows on the face of the wall.
- (Optional) You can refine the window design by changing the default values of the parameters. To do this, select the window and change the desired parameters in the Properties panel.
To change one of the default parameters of this window, type a new value in the property field.
Press Enter to accept the new value of the parameter. The window should be updated automatically.
Create windows based on a grid
- Use BIMGRID command to create a Grid on the face of the wall. Choose the basic dimensions in the Command line. Changing the U-line and V-line panel options allows you to specify the desired size and number of panels on the surface.Note: To draw on the face, make sure you first highlight the face and then click to start drawing. Otherwise, the Grid will be created in the XY-plane.
- Use BEDIT command or REFEDIT command to edit the Grid.
Use the Manipulator to change the position of the gridlines on the wall.
- Select the Grid and then select Create Window in the Quad.
- The window is generated based on the gridlines.Note: You can edit the parameters in the Properties panel. Type a new value in the property field and press Enter. The window will automatically update itself.
Creating window openings
- Draw one or more closed polylines on the face of a wall.
- While boundary detection is on, hover over the polygon.
Or select the closed polyline.
- Select the Create Opening tool from the Quad.
- The opening is created based on the closed contour. In the Structure Browser, the opening is added as a block reference. The block reference is classified as an opening.
If you select the opening from the Structure Browser, you will see a set of properties related to this opening element in the Properties panel.
Note: If your closed contour has a rectangle shape, the opening element will include Width and Height parameters.Note: Opening elements contain subtractor solids. To display the subtractor solid, open the Layers panel and select the BC_SUBTRACT layer.Note: The associative tags can be generated using the BIMTAG command for the opening element in a sectioned drawing.
The following animated GIF file demonstrates how to create an opening based on a closed contour.
