Sheet Metal Commands and Toolbars
Sheet Metal Toolbar icon | Flyout Toolbar icon | Command | Description |
SMFLANGEBASE command | Create a base (initial) flange of a sheet metal part from a closed planar profile. | ||
SMEXTRUDE command | Create a sheet metal part by extruding a polyline in the direction of the normal of the curve plane. Thickness is assigned with respect to the external dimensions of the polyline. | ||
SMLOFT command | Create sheet metal part with lofted bends and flanges from 2 non-coplanar curves. | ||
SMCONVERT command | Automatically recognize flanges, bends and lofted bends in a 3D solid. | ||
SMFLANGEEDGE command | Create one or more flanges on a sheet metal part by pulling one or more edges of an existing flange. | ||
SMFLANGECONTOUR command | Create a new flange from a closed contour and attach it to an existing sheet metal part. | ||
SMFLIP command | Change the reference side for selected flanges with an optional shift of the flange geometry by thickness. | ||
SMFLANGEROTATE command | Rotate a flange. | ||
SMHEMCREATE 命令 | Create one or more closed hem features on a sheet metal part by pulling one or more edges of an existing flange. | ||
SMHEMCREATE 命令 | Create one or more open hem features on a sheet metal part by pulling one or more edges of an existing flange. | ||
SMHEMCREATE 命令 | Create one or more Teardrop hem features on a sheet metal part by pulling one or more edges of an existing flange. | ||
SMHEMCREATE 命令 | Create one or more Round hem features on a sheet metal part by pulling one or more edges of an existing flange. | ||
BMINSERT command | Insert form features. | ||
SMFORM command | Create form feature from given set of faces. | ||
SMFORM command | Explode form feature in flanges and bend if possible. | ||
SMRIBCREATE 指令 | Create an associative rib form feature on a flange face from a planar 2D curve. | ||
SMREPLACE command | Replace form features (including recognized ones) in sheet metal parts with form features from a built-in or user library. | ||
SMBENDCREATE 命令 | Convert hard edges (sharp edges between flange faces) and junctions into bends. | ||
SMBENDSWITCH command | Convert bends to lofted bends. | ||
SMFLANGEBEND command | Bend an existing flange along a line, obeying k-factor for given bend radius. | ||
SMJUNCTIONCREATE command | Convert hard edges into junctions. | ||
SMJUNCTIONSWITCH command | Change a symmetrical junction feature to one with overlapping faces. | ||
SMFLANGECONNECT 命令 | Close gaps between 2 arbitrarily oriented flanges. | ||
SMTABCREATE command | Create single tab feature to a sheet metal part by switching existing junction into the tab. | ||
SMTABCREATE command | Create array tab feature to a sheet metal part by switching existing junction into the tab. | ||
SMRELIEFCREATE command | Make proper corner and bend reliefs. Corner reliefs are built on corners which have 3 or more adjacent flanges. Bend reliefs are built on the start and end of a flange edge. | ||
SMRELIEFSWITCH command | Convert a corner relief to a circular relief. | ||
SMRELIEFSWITCH command | Convert corner reliefs to a rectangular relief. | ||
SMRELIEFSWITCH command | Convert corner reliefs to a VType relief. | ||
SMRELIEFSWITCH command | Convert corner reliefs to a Smooth relief. | ||
SMRELIEFSWITCH command | Convert corner reliefs to a Round relief. | ||
SMRELIEFSWITCH command | Convert corner reliefs to a Rip relief. | ||
SMSPLIT command | Split a flange along a line drawn on its face. | ||
SMSPLIT command | Split a flange by a single vertex in the corner. | ||
SMSPLIT command | Split a flange by a single vertex in the corner and automatically suggest multiple splits of a similar type. | ||
SMIMPRINT command | Split thickness faces of a sheet metal part by imprinted edges, according to adjacent flanges and bends. | ||
SMDISSOLVE command | Remove sheet metal data from the selected faces or entities. | ||
SMDELETE command | Remove a bend or a junction by restoring a hard edge between two flanges; remove a flange with all the bends adjacent to it. The adjacent flanges are extended up to a junction configuration with the flange being deleted. Remove miter by restoring geometry being cut by the feature. | ||
SMREPAIR command | Fix problems specific to Sheet Metal parts, both global and local workflows are supported. Optionally heal lofted bend features: merge adjacent bends and provide tangential connection with flanges. | ||
SMREPAIR command | Fix problems specific to Sheet Metal parts. Only selected flange or wrong bend are repaired. | ||
SMSELECT command Same form features | Select all identical form features in the sheet metal model. | ||
SMSELECT command Hard edges | Select all hard edges on sheet metal parts. | ||
SMSELECT command Non-orthogonal thickness edges | Select all non-orthogonal thickness edges on the sheet metal part. | ||
SMSELECT command Flat edges | Select flat edges on the sheet metal part. | ||
SMSELECT command side of the sheet metal part | Select side of the sheet metal part. | ||
SMPARAMETRIZE command | Create a consistent set of 3D constraints for the selected sheet metal part. | ||
SMUNFOLD command | Unfold the sheet metal body. | ||
Associatively SMUNFOLD command | Open an additional window with model's unfolded representation. | ||
SMEXPORTOSM command | Export a sheet metal solid to the .osm (Open Sheet Metal) file format. | ||
SMEXPORT2D command | Export the unfolded representation of a sheet metal body as a 2D profile in .dxf / .dwg file format. | ||
SMASSEMBLYEXPORT command | Perform a batch export of assembly components to unfolding, creating a .dxf per each 3D solid recognized as sheet metal part. | ||
FEATURECOLORS system variable | Toggle the FEATURECOLORS system variable. |
The Sheet Metal tools are available:
- In the Quad cursor menu (depending on the feature under the cursor):
- On the Sheet Metal toolbars:
- Sheet Metal
- SM Bend
- SM Flange
- SM Form
- SM Hem
- SM Junction
- SM Relief
- SM Repair
- SM Split
- SM Tab
- SM Unfold
- Sheet Metal
- In the Sheet Metal menu (Mechanical workspace only):
- In the Sheet Metal tab of the Mechanical workspace ribbon.
See also Direct modeling operations.
