Attribute editor dialog box
The attribute Editor dialog box allows you to edit attributes within blocks.
Overview list
Displays an overview of all attributes used in the block.
Value
Displays the currently selected attribute from the list. A new value can be typed.
Properties
Specifies properties of the selected attribute.
- Layer
- Specifies the layer of the selected attribute.
- Color
- Specifies the color of the selected attribute.
- Linetype
- Specifies the linetype of the selected attribute.
- Plot style
- Specifies the plotstyle of the selected attribute.
Text Options
- Text style
- Specifies the font of the text in the selected attribute.
- Justification
- Specifies the alignment of the text in the selected attribute.
- Upside down
- When checked, text is displayed upside down.
- Backwards
- When checked, text is displayed backwards.
- Height
- Specifies the height of the text in the selected attribute.
- Rotation
- Specifies the rotation angle of the text in the selected attribute.
- Width factor
- Specifies the width of the text in the selected attribute.
- Oblique angle
- Specifies the oblique angle of the text in the selected attribute.
