The Start tab
The Start tab is located on top of the drawing area, before the document tab(s), and has two sections: Home and Learn.
The Start tab is active by default. If you accidentally closed the tab, you can reopen it with the Ctrl+Home keyboard shortcut or with the GOTOSTART command.
Note: The SHOWDOCTABS system variable needs to be ON to display the Start tab.
Home
- Workspace
- Start from template
- New drawing
- Open files
- Get to know BricsCAD
- Recent files
- Right-side tab
- Workspace
- Allows you to choose the workspace from the drop-down menu.
- Displays the last used templates. Click the More... button to open the Create New Drawing From Template dialog box. You can select a template from the list or you can browse for a custom template to create a new drawing.
- New drawing
- Creates a new drawing using the current drawing template.Note: Using the BIM workspace, you can choose between creating a new project or a new drawing.
Click the right-side arrow to display additional options:
- Create new sheet set
- Opens the Create New Sheet Set dialog box.
- Start new wizard
- Opens the Create New Drawing dialog box.
- Open files
- Opens the Open file dialog box to browse for an existing drawing.
- Open files (read-only)
- Opens the file selected from the Open file (read-only) dialog box only for reading.
- Open a sheet set
- Opens the Select a Sheet Set file dialog box to browse for a sheet set file.
- Provides step-by-step guidance for using BricsCAD® in the selected workspace. The TUTORIALSOPEN command launches.Note: The TUTORIALSONSTARTPAGE system variable controls the display of this option.
- Recent files
- Displays a list of recently opened files. Click the thumbnail image of the file to easily open it.Note: The number of available recent files is controlled by the value of the RECENTFILES system variable.Note: You can arrange the file in Grid view or Table view mode and you can search for a specific file.
- Right-side tab
- Groups information about BricsCAD®.
Learn
Offers free video lessons to learn BricsCAD® and sample drawings for use.
