BricsCAD system requirements
System requirements and recommendations.
Supported Operating Systems |
Minimum CPU:
Recommended CPU:
The CPU with the highest single-thread performance rating will always excel with BricsCAD®. Additional CPU cores will bring in higher performance, as more and more functions gets multithreaded computation in BricsCAD®. Note:
Minimum System Memory: 8 GB |
Recommended System Memory:
For maximum performance, determine the memory configuration of your PC and ensure that each memory channel on the motherboard is populated with at least one memory module. |
Minimum Disk Space: 3 GB for BricsCAD® Ultimate, installed |
Recommended Disk Space: (As needed) |
We strongly recommend using SSD (Sata 3 / PCI-E NVME) as system drives, for both BricsCAD® and Windows. Drawings and support files can reside on slower mechanical hard disk drives, if necessary. Note: Solid-state disks can be up to 10x faster reading and 20x faster writing data than a mid-range hard disk drive
Minimum Display System:
Recommended Display System:
On Microsoft Windows systems, most graphics cards & GPUs from NVIDIA, AMD and Intel® are supported. Note: If you work with point clouds and big models in the model space, we advise changing Windows' Graphic settings as follows:
On Linux systems, most graphics cards and GPUs from NVIDIA and AMD are supported. On Mac systems, native Apple display hardware is supported. BricsCAD®’s non-wireframe display modes are generated by RedSDK technology from Redway3D®. The GPU is used to render this modes. Note: We suggest that you install the latest drivers available for your display hardware, as recommended by the manufacturer.
Note to Linux users: Hardware acceleration of 3D graphics on Linux systems is NOT supported on:
