Match properties
The MATCHPROP command (short for "match properties") assigns the properties of one entity to other entities.
![](https://static.bricsys.com/help/images/V23/en_INTL/matchprop.png)
Copying properties between entities
- Launch the MATCHPROP command.
- You are prompted: Select entity to copy properties from:
- Select the source entity.
- You are prompted: Active Settings: 'Color' 'Layer' 'Linetype' 'Linetype Scale' 'Lineweight' 'Thickness' 'Plot Style' 'Dimension' 'Polyline' 'Material' 'Text' 'Shadow Display' 'Hatch' 'Multileader' Select entities to copy properties to or [Settings/selection options (?)]:
- (option) Choose the Settings option, then press Enter.
Adjust the settings, then click the OK button.
- Select the target entities.
- You are prompted: Select entities to copy properties to or [Settings/selection options (?)]:
- Keep selecting entities or right-click to stop.
Copying properties between entities with BIM data
Whether the MATCHPROP command copies BIM data depends on the value of the BIMMATCHPROP system variable.
- BimMatchProp = 0: Match standard properties
Only standard properties will be copied, according to the currently selected options (see above).
- BimMatchProp = 1: Match standard and BIM properties
BIM data, including IFC properties and user defined properties are copied, except:
- BIM Type*
- Composition/Profile
- GUID
- Quantities
* When using MATCHPROP between a BIM classified entity and an entity without any BIM data, the BIM type and the corresponding BIM properties will be copied along to the unclassified entity, except Composition/Profile, GUID and Quantities.
