ALIGNMENTCURVE command
Creates Horizontal Alignment unconstarined curve.
Icon:
方式
There are two metods:
- Select an existing horizontal alignment to add new elements.
- Create new alignment.
Options within the command
- Creates new Horizontal Alignment entity by specifying a center point.
- Specify curve direction
- Toggles between clockwise and counterclockwise direction.
- Points
- Creates Horizontal Alignment curve by specifying the start point, second point and end point.
