-BMPARAMETERS command
Allows to list and edit the parameters of inserted components and associative arrays.
Allows to list and edit the parameters of inserted components and associative arrays. By pressing Enter, the parameter expression can be changed.
Note: Parameters of components nested inside an array can be changed or assigned to an expression.
Options within the command
Edit
Edits the value of a parameter.
Delete
Allows to reset a previously edited parameter to its default value.
Link to parameter
Assigns parameters as an expression for a parameter of a dimensional constraint (both 2D and 3D) associated with an entity which has been put into an associative array.
Lists the parameter, expression and value of the selected components in the Prompt History window.
Note: Press F2 to display the Prompt History window.
