BIMATTACHCOMPOSITION command
Attaches a BIM composition to solids.
Icon:
Method/s
This command offers 3 methods to attach the compositions.
  • Enter the composition name
  • Compositions dialog box
  • 选取对象
Options within the command
对话框(D)
Opens the Compositions dialog box.
See BLCompositions for more information about the dialog.
实体
Applies the composition of an existing solid. First you select the entities to copy the composition from, next you select one or multiple entities to attach the composition to.
分离(T)
Allows to detach a composition, while keeping the BIM classification, as different from the Unclassify option of the BIMCLASSIFY command, which removes all BIM data.
