BIMTAG command
Creates associative tags.
Icon:
描述(D)
Creates associative tags in generated BIM section drawings for the corresponding building entities in a 3D BIM model.
Note: This command can only be used on section viewports.
Note: The GENERATEASSOCVIEWS system variable must be ON when generating or updating BIM tags.
方式
The tags are created automatically for all building elements in the selected viewport.
Note: Tags are created as multileader entities using multileader styles in _SectionTag.dwg. The content of such multileader style is a block with attributes. Each attribute refers to a property of a BIM entity type. BIM entity types are linked to a multileader style in _TagTypeToStyle.xml. All source files can be found in the Support folder, for example: C:\Users\<UserName>\AppData\Roaming\Bricsys\BricsCAD\V18x64\en_US\Support\Bim\Sections.
Options within the command
- 自动
- Creates tags automatically for all sectioned building entities in the selected viewport.
- 手动(M)
- Creates tags on background entities in sections and elevations.
- 目前多重引线样式
- Allows to use the current multileader style instead of the default style for selected sectioned BIM elements.
- 更改标签类型
- Changes the type of the selected tags.
- 组成
- Tag with all materials of composition of the sectioned BIM element.
- 承重方向
- Inserts a loadbearing direction symbol when a generated line of a slab solid is selected. Make sure the load bearing direction is set by the BIMSETLOADBEARINGDIRECTION command.
- 点标高
- Inserts a tag that indicates the elevation of the identified point in elevations and vertical sections.
- 更新现有
- Updates the existing tags in the selected viewport. The position of relocated tag blocks is preserved.
- update existing and add New
- Updates the existing tags in the selected viewport and adds new tags.
- 全部重生
- Updates all tags in the selected viewport. Repositioned tag blocks are moved to their default location.
