BMBALLOON command
Creates associative balloon entities for assembly components.
Icon:
描述(D)
Creates associative balloon entities for assembly components in Model Space and for their generated views in a Paper Space layout. Each balloon contains an index of the component in the associated BOM-table created by BMBOM command.
Note: Balloons are created as Multileader entities using the current Multileader style. Create a Multileader style with the Content set to Block and adjust the Scale property to control the size of the balloon frame.
Options within the command
- select other Table
- Allows to select a different BOM-table in case multiple tables exist in the layout. The most recently inserted BOM-table is selected by default.
- select balloon Style
Allows to define the shape of the balloon.
Note: Predefined balloon styles from _BalloonStyles.dwg can be used, as well as any custom user-defined styles.Note: The PROMPTMENU variable allows the selection of the balloon styles.
- 自动模式
- Allows automatic placement of balloons on all components in a particular drawing view.
- placement Mode
- Specifies whether multiple balloons with the same values are generated or not.
- 独特
- Only unique values are generated on one view.
- 全部
- All values are generated on one view.
- 圆(C)
Aligns leaders along a circle.
- 多段线(P)
Aligns leaders along a polyline.
- 后
- Returns to previous prompt.
