BMMECH command
Converts the current drawing into a mechanical component.
Icon:
描述(D)
If the drawing contains block references or external references, they can also be converted into inserts of local and external components.
If the drawing is a mechanical component already, BMMECH does nothing.
Options within the command
- 是
- If the drawing contains block references or external references, blocks are converted to internal components and external references are converted to external components.
- No
- The mechanical structure is initialized but blocks and external references are not converted.
