DMANGLE3D command
Creates an angle constraint between faces and/or edges of 3D solids, WCS subentities and subentities of a coordinate system of a block.
Icons:
描述(D)
Creates an angle constraint between faces and/or edges of 3D solids, WCS subentities, and subentities of a coordinate system of a block. Creates a Planar Angle constraint by default: coordinate planes of the WCS are used as third reference objects whenever possible. It also allows to control the top angle of a cone. Press the TAB key to select obscured geometry.
选项(O)
- 锥角度约束
- Allows you to control the top angle of a cone by specifying the angle between the axis and the cone face (= cone half angle). Values must be smaller than 90°.
- 世界
- Allows you to select the WCS subentity as an argument.
- 图块
- Allows you to choose, as an argument, the subentity of the coordinate system of the block. You can choose from: X axis/Y axis/Z axis/XY plane/YZ plane/ZX plane.
- 设置参考对象
- Allows you to manually specify the reference entity:
- 几何驱动
- Accepts the current value and creates a geometry-driven constraint.
