EXPUCS command
Creates, renames and deletes named UCS's through the Drawing Explorer dialog box.
Alias: DDUCS, UC
Opens the Drawing Explorer dialog box on the Coordinate systems category:
Options within the columns
Current
Indicates the current UCS.
UCS Name
Lists the names of UCS's in the drawing; click to rename.
Origin (WCS)
Reports the origin (0,0,0) of the UCS in x,y,z coordinates of the WCS; cannot be edited.
X Axis Direction (WCS)
Reports the direction of the x axis in WCS coordinates.
Note: Cannot be edited.
Y Axis Direction (WCS)
Reports the direction of the y axis in WCS coordinates.
Context Menu Options
New
Creates additional UCS into the drawing through the model space.
Delete
Deletes Coordinate system from the drawing. The World coordinate system definitions cannot be deleted.
Rename
Renames the Coordinate System.
Select All
Selects all Coordinate System definitions.
Invert selection
Deselects the current selection and vice versa.
Set current
Sets the selected Coordinate System as current.
