LINE command
Creates line segments.
Icon:
Alias: 3DLINE, L
描述(D)
Creates a series of individual line entities by specifying the start and endpoint of each segment. Options allow you to specify the angle, undo, and close the geometry.
Methods to begin a line
This command has 3 methods to begin creating a line segment:
- 指定线起点
- 最后点
- 跟随
You can continue adding unlimited segments until you press Enter to end the command.
- 指定线起点
- Begin creating a line by specifying the start point then:
- Set end point
- Specify the end point of the line segment.
- 最后点
- Begin creating a line from the last point picked then:
- Set end point
- 跟随
- Begin creating a line from the last drawn arc or line segment, following its angle, then:
- 指定线长度
- Specify the length of the line. Picking the endpoint only determines the length since the angle follows the previous segment.
Options within the LINE command
After you begin creating a line, the following options may be available:
- 角度
- Specify the angle of the line segment.
- 长度
- Specify the length of the line segment.
- 撤销(U)
- Undo the last line segment and continue drawing from its previous start point.
- 关闭
- Automatically draw a line from the end point of the last segment to the start point of the first segment.
