MANIPULATE command
Launches the manipulator widget to rotate, move, copy, mirror, and/or scale 2D entities and 3D models.
Icon:
Methods
There are multiple methods to access the manipulator.
- Manipulate command
Select entities and press enter.
- 导航
- Long press an object
Make sure the MANIPULATOR system variable is set right.
选项(O)
- Select an axis
- Moves the selection of entities along the selected axis.
- Select a plane
- Moves the selection of entities in the selected plane.
- Select an arrowhead
- Mirrors or scales the selection. By right clicking when hovering over the entity, a contexts menu with other options is displayed. There the function of an arrowhead can be changed between 3D mirror and 3D scale.
- Select a rotation arc
- Rotates the selection around one of the manipulator axes. Enter the rotation angle value or specify by clicking on a point in the drawing.
- Select the anchor handle
- Moves the manipulator. Specify a point to relocate.
