OFFSET command
Creates parallel copies.
Icon:
Alias: O
描述(D)
Creates parallel copies of 2D entities and 3D solid faces.
Note: The OFFSETGAPTYPE system variable determines how potential gaps between segments are treated when polylines are being offset.
Note: The SELECTIONMODES system variable determines how potential conflicts are handled.
Note: When curved entities are offset, the command changes the radii of the copies.
方式
There are four methods to create an offset:
- 输入偏移距离
- 通过点
- 删除
- 图层
Options within the command
- 输入偏移距离
- Specifies the distance between the original entity and its parallel copy.
- 两侧
- Places offset copies on both sides of the entity.
- 多重(M)
- Repeats the command until you press ESC.
- 通过点
- Specifies the offset distance by picking two points.
- 多重(M)
- 删除
- Deletes the source entity after the offset operation.
- 图层
- Specifies the layer on which to place the copied entity.
- 目前
- Places the offset entity on the current layer.
- 源
- Places the offset on the same layer as that of the source entity.
