PASTEBLOCK command
Pastes CAD entities from the Clipboard as a block.
![BricsCAD Shape; BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-all.png)
Icon:
Note: Before you can use this command, first use the COPYCLIP
or COPYBASE commands to copy entities from the current drawing, or even from
another CAD program.
This command can only paste CAD entities into the drawing as block entities. Other Clipboard content may be pasted as OLE entities.
