PDFIMPORT command
Imports a PDF and converts its content to simple CAD entities.
Icon:
方式
This command also converts a PDF underlay already attached to the drawing to CAD entities.
Different conversions are made depending on the type of the PDF entity.
PDF entity | CAD Entity |
Straight and curved lines | Polylines and splines |
SHX text | 多段线(P) |
TrueType 文字 | 多行文字 |
Solid-filled areas and wide lines | Hatches with 50% transparency |
点阵图像 | 点阵图像 |
图层 | 图层 |
Lines with linetypes | Polyline segments |
There are 2 methods to convert a PDF to CAD entities
- PDF底层
- PDF file
选项(O)
Underlay options
- Specify area
- Picks the first two points to convert a rectangular area of an underlay to CAD entities.
- 多边形
- Picks three or more points to convert a polygonal area of an underlay to CAD entities.
- 全部
- Selects the entire PDF underlay for conversion to CAD entities.
- 设置(S)
- Displays the PDF Import Settings section of the Setting dialog box.
- 保留
- Keeps the PDF underlay in place, in addition to converting its vector portions to CAD entities.
- 分离
- Detaches the PDF underlay so that it is no longer seen in the drawing but is still attached to the drawing.
- 卸载
- Unloads the PDF underlay so that it is no longer seen the drawing but is still attached to the drawing.
Import file Options
- 页数
- Imports a specific page from the PDF file. When pressing enter, the first page will be imported.
- Lists the page number in the PDF document.
- 设置(S)
- Displays the PDF Import Settings section of the Settings dialog box.
- 插入点
- Specifies the insertion point in the drawing.
- 比例(S)
- Specifies the scaling factor or the inserted geometry.
- 旋转(R)
- Specifies the rotation angle.
