RENAME command
Renames named entities through the Drawing explorer dialog box.
Alias: DDRENAME, REN
Opens the Drawing Explorer dialog box on the last used tab or category to manage definitions and reference content that is used in the drawing. Rename can be accessed through the context menu.
Note: To change names at the Command line, use the -RENAME command.
You cannot change the names of attached files, such as images and external references, nor the following names:
  • Layer "0"
  • Linetype "ByBlock", "ByLayer", or "Continuous"
  • Text style "Standard"
  • Dimension style "Standard"
  • Multiline style "Standard"
  • Visual style "2DWireframe"
  • Material "Global"
  • Page layouts that have * as a prefix and suffix, such as *Model*
  • View detail style "Metric50"
  • View section style "Metric 50"
