SECTIONPLANESETTINGS command
Icon:
Opens the Drawing Explorer dialog box with Section Planes category selected.
Methods
Open the Drawing explorer dialog box with Section Planes category selected to view and modify section planes in the current drawing.
Note: The available options differ depending on the kind of section you choose to edit.
Options within the command
Section Types
2D Section/elevation block creation settings
Specifies properties for 2D sections and elevations. These properties are assigned to the 2D section you create as a block.
3D section block creation settings
Specifies properties for 3D sections. These properties are assigned to the 3D section you create as a block.
Live Section Settings
Specifies properties for live sections. With live sections, the entities in the drawing are temporarily modified and viewable in the drawing.
Clip Display Settings
When using the clip display status, the display of entities is clipped. The status can be set for multiple section entities simultaneously.
Destination
Destination file
Specifies the destination file to save the section plane to.
Intersection Boundary
Color
Defines the color of the intersection boundary. You can choose a color from the drop list or choose Select Color, the Color dialog box will then display.
Layer
Specifies the layer of the intersection boundary. You can choose between:
  • The available layers in the drawing.
  • *EntityLayer*_IntersectionBoundary: the properties of layers of the entities in the section are kept, but a copy of these layers is created.
    Note: This overwrites the other specified properties.
  • New layer name settings: option opens the New Layer Name dialog box. Here you can edit the name settings for the option above.
Linetype
Specifies the linetype of the intersection boundary. You can choose between:
  • The available linetypes in the drawing
  • Load to load new linetypes. This opens the Load Linetypes dialog box where you can choose new linetypes to load into the drawing.
Linetype scale
Specifies the linetype scale of the intersection boundary.
Plot style
Specifies the plotstyle of the intersection boundary.
Lineweight
Specifies the lineweight of the intersection boundary.
Division lines (option available for the 2D sections)
Specifies whether the division lines of the intersection boundary should be drawn.
Show (option available for the 3D sections)
Specifies whether the intersection boundary is drawn.
  • Yes: the intersection boundary is displayed. The intersection boundaries are indicated in blue.
  • No: no intersection boundary is displayed.
    Note: The intersection boundary is still visible, since the lines are also drawn for the intersection fill. The color is now determined by the intersection fill instead of by the intersection boundary.
Intersection Fill
Show
Specifies whether the intersection filling is showed.
  • Yes: the cut through geometry is displayed by a hatch
  • No: no hatch is drawn on the cut through geometry
Face hatch
Specifies the used hatch pattern to fill the section. Opens the Hatch Pattern Type dialog box where you can choose a hatch pattern.
Angle
Specifies the angle of the hatch pattern.
Hatch scale
Specifies the scale of the hatch pattern.
Hatch spacing
Specifies the hatch spacing.
Color
Specifies the color of the hatch. You can choose a color from the drop list or choose Select Color, the Color dialog box will then display.
Layer
Linetype
Linetype scale
Specifies the linetype scale of the hatch pattern.
Plot Style
Specifies the plot style of the hatch pattern.
Lineweight
Specifies the lineweight of the hatch pattern.
Background Lines
Show
Specifies whether the background lines are drawn. These are the lines that show the geometry behind the section plane, which is not cut-through.
  • Yes: the background lines are displayed
  • No: no background lines are displayed
Color
Specifies the color of the background lines. You can choose a color from the drop list or choose Select Color, the Color dialog box will then display.
Layer
Specifies the layer of the background lines. You can choose between:
Linetype
Specifies the linetype of the background lines. You can choose between:
Linetype scale
Specifies the linetype scale of the background lines.
Plot Style
Specifies the plot style of the background lines.
Lineweight
Specifies the lineweight of the background lines.
Hidden lines
Show
Specifies whether the hidden lines are drawn.
  • Yes: the hidden lines are displayed.
  • No: no hidden lines are displayed.
Color
Specifies the color of the hidden lines. You can choose a color from the drop list or choose Select Color, the Color dialog box will then display.
Layer
Specifies the layer of the hidden lines. You can choose between:
Linetype
Specifies the linetype of the hidden lines. You can choose between:
Linetype scale
Specifies the linetype scale of the hidden lines.
Plot Style
Specifies the plot style of the hidden lines.
Lineweight
Specifies the lineweight of the hidden lines.
Cut-away Geometry
Show
Specifies whether the section lines of the geometry that is cut away are shown.
  • Yes: the cut-away geometry is displayed.
    Cut-away geometry of a 2D section.
    Cut-away geometry of a 3D section.
    Cut-away geometry of a live section.
  • No: no cut-away geometry lines are displayed
    No cut-away geometry of a 2D section is shown.
    No cut-away geometry of a 3D section is shown.
    No cut-away geometry of a live section is shown.
Hidden line
Specifies whether the hidden lines of the cut-away geometry are shown.
Color
Specifies the color of the cut-away geometry (lines). You can choose a color from the drop list or choose Select Color, the Color dialog box will then display.
Layer
Specifies the layer of the cut-away geometry. You can choose between:
Linetype
Specifies the linetype of the cut-away geometry. You can choose between:
Linetype scale
Specifies the linetype scale of the cut-away geometry lines.
Plot Style
Specifies the plot style of the cut-away geometry lines.
Lineweight
Specifies the lineweight of the cut-away geometry lines.
Curve Tangency Lines
Show
Specifies whether the curve tangency lines are drawn.
Color
Specifies the color of the curve tangency lines. You can choose a color from the drop list or choose Select Color, the Color dialog box will then display.
Layer
Specifies the layer of the curve tangency lines. You can choose between:
  • New layer name settings: option opens the New Layer Name dialog box. Here you can edit the name settings for the option above. See the related article New Layer Name dialog box.
Linetype
Specifies the linetype of the curve tangency lines. You can choose between:
Linetype scale
Specifies the linetype scale of the curve tangency lines.
Plot Style
Specifies the plot style of the curve tangency lines.
Lineweight
Specifies the lineweight of the curve tangency lines.
Context Menu Options
New
Creates a new section plane definitions into the drawing. For a detailed explanation, see the SECTIONPLANE command.
Delete
Deletes section planes from the drawing.
Rename
Renames the selected section plane.
Select All
Selects all section plane definitions.
Invert selection
Deselects the current selection and vice versa.
