Automatically recognizes sheet metal features.
Icon:
描述(D)
Automatically recognizes flanges, bends, lofted bends, ribs, form features and holes for selected 3D solids.
Options within the command
- 整个模型
- Applies the command to the entire model.
Note: All the solids in the model are analyzed and if possible, converted to Sheet Metal bodies. The command recognizes sheet metal features (such as flanges and bends) in the input geometry. The body thickness of the sheet metal drawing is the criteria in case multiple solids are selected. Therefore, selected bodies must have the same thickness, otherwise an error message displays in the command window.
