VISIBILITYSTATESSHOW command
Shows entities for the active state of the selected visibility parameter.
Methods
The VISIBILITYSTATESSHOW command shows entities for the active state of the selected parameter.
Options within the command
- Specify parameter name
- Asks for the name of an existing visibility parameter.
- Select entities to make visible for <P>=<S> [selection options (?)]:
Asks for a selection of entities to be visible when the state <S> is active.
<P> is a placeholder for the name of the visibility parameter entered in the previous step. <S> is a placeholder for the name of the active visibility state of the parameter <P>. On the screen, instead of the texts <P> and <S>, the actual names of the parameter and the state will be displayed.
For more information on viewing and managing the visibility parameters and states see the article Visibility states panel.
