WEDGE command
Creates a 3D Solid in the shape of a wedge.
Icon:
Alias: WE
Note: In BricsCAD Lite, which doesn’t support 3D Solids, the WEDGE command launches the AI_WEDGE command.
描述(D)
Creates a 3D solid in the shape of a rectangular or square wedge. Choose from a combination of options including corner, center, length, height, and cube.
Methods to create a wedge
This command has 2 methods to begin creating a wedge:
- Set corner of wedge
- 中心(C)
- Begin creating a wedge by specifying a corner for the base of the wedge then:
- Set opposite corner
- Specify the opposite corner for the base of the wedge to apply both the length and width. The wedge is created parallel to the x and y axes.
- 指定楔形体高度
- Specify the height of the wedge. The tall end of the wedge is drawn from the first corner that you specified.
- 中心(C)
- Begin creating a wedge by specifying the center of the wedge then:
- Specify a corner on the midplane of the wedge to apply both the length and width of the wedge’s base. The wedge is created parallel to the x and y axes.
- 指定楔形体高度
Options within the WEDGE command
After you begin creating a wedge, the following options may be available:
- 立方体(C)
- Specify a single distance to use for the length, width, and height of the wedge.
- 边长
- Specify the length and angle for one side of the wedge then:
- 指定楔形体宽度
- Specify the width of the wedge.
- 指定楔形体高度
- 2点
- Specify the height of the wedge as the distance between any two points.
