ANNOAUTOSCALE system variable
Annotation scaling
Synchronizes new annotative entities with the current annotation scale.
Type: |
Short |
Saved in: | Registry |
Default value: | -4 |
Possible values: |
0: Do not add to annotative entities. 1: Add to annotative entities that support it, except entities on locked, turned off, frozen or viewport-frozen layers. 2: Add to annotative entities that support it, except entities on turned off, frozen or viewport-frozen layers. 3: Add to annotative entities that support it, except entities on locked layers. 4: Add all annotative entities supporting it. -1: Do not add to annotative entities (toggled value 1). -2: Do not add to annotative entities (toggled value 2). -3: Do not add to annotative entities (toggled value 3). -4: Do not add to annotative entities (toggled value 4). |
