ANTIALIASSCREEN system variable
Anti-alias amount for screen
Specifies the smoothness of on-screen curve display. For values higher than 1 and visual style 2DWireframe (which uses GDI), calculation of an anti-aliased display comes at a high performance cost (roughly a factor 7). For the other display modes the calculation time increases with less than 50%.
BricsCAD only
Type: |
Short |
Saved in: | Preference |
Range: | 1 to 5 |
Default value: | 1 |
Possible values: |
1: 1x1 (no anti-aliasing) 2: 2x2 3: 3x3 4: 4x4 5: 5x5 (maximum anti-aliasing) |
