ATTMODE system variable
属性显示方式
Specifies whether attributes are visible or not. If the ATTMODE variable is set to 2, all attributes display, including Hidden attributes.
Type: |
Short |
Saved in: | Drawing |
Default value: | 1 |
Possible values: |
0: 所有属性都不可见 1: As defined in block 2: Show all |
