AUDITCTL system variable
核查控制
Toggles the creation of audit report (ADT) files by the AUDIT command. When you turn on the AUDITCTL settings variable, Audit creates an ASCII file describing problems and the action taken. This report, with the file extension .adt, is placed in the same directory as the current drawing.
Type: |
Boolean |
Saved in: | Registry |
Default value: | Off |
Possible values: |
Off (0): Don’t write ADT files On (1): Write ADT files |
